Final Edits
An easy landscape tutorial using Topaz Clarity and Photoshop.
by Joe Reardon
  • Location: Schwabacher’s Landing, Grand Teton National Park, Wyoming
  • Equipment: Nikon D800 wwith a 14-24 MM lens. This is a 5 image HDR, processed in Photoshop HDR Pro. F13 @ ISO 400 +1 +2   &  -1 -2
Step 1
  • Load the image into Photoshop
  • Create a duplicate layer (Ctrl/Cmd + J) and rename to Clarity
No Edits-1
Step 2
  • Activate Topaz Clarity
  • Press ‘Reset All’
Step 3
  • Make adjustments to ‘Dynamics’, ‘Tone’ and ‘Luminosity’ as shown:
Step 4
  • Make adjustments to the ‘Mask Feather’ under the Clarity tab and create a mask as needed:
Split Screen
Split Screen-2
Step 5
  • Flatten image and save
Final Image in Clarity
Final Edits ClarityStep 6 (if needed)
  • Create a new adjustment layer
  • Rename layer to Luminosity
  • Switch to Channels tab
  • Ctrl/Cmd + click the RGB layer to get ‘marching ants’
  • Create a Curves layer and adjust highlights as needed
  • Make sure that the blending mode is set to Luminosity
Marching Ants-2
Highlights Curves Mask
Highlights Full Screen
Step 6
  • Repeat the Ctrl/Cmd + click on the RGB Luminosity layer
  • Create a Curve Layer
  • Select the new curve layer and press Ctrl/Cmd + I to invert the selection.
  • Adjust the curve layer as needed–make sure the blend mode is Luminosity
Darks Curves Mask
Darks Mask Full-1
Step 7
  • Flatten the layer and save as ‘Final Edits’
Final Image
Final Image
About the Photographer:
Joe Reardon is a freelance photographer from southern New Hampshire. Joe’s work is represented by galleries in New Hampshire and in Massachusetts. Joe’s images are also in private collections across the USA and in Europe. His photo website can be found here.
Share this
Share on Facebook2Tweet about this on TwitterShare on Google+0Pin on Pinterest22Share on LinkedIn0Share on Reddit0Share on Tumblr0Email this to someonePrint this page
Tagged , , , , , , .
