In our newer updates to Topaz Adjust, Topaz Detail, and Topaz ReMask, we’ve used an plug-in user interface that was rebuilt from the ground up. Hopefully this interface is both easier to use and easier on the eyes than the old one. However there were some kinks that we had to work out:
Some users have experienced a drastic difference between the colors of the previewed image and the result when using the newer versions of Topaz Adjust and Detail. Other users have experienced crashes when using the new Adjust, Detail, or ReMask. We’ve been hard at work solving these issues, and today the patch is ready for download. This should solve both the color management problem and the crashes.
To apply the patch, re-download and re-install the appropriate software at the following link. (Windows users will have to first uninstall their old software using Add/Remove Programs and then install the new version.)
Topaz Downloads
This only affects Topaz Adjust 4, Topaz Detail 2, and Topaz ReMask.
If you still have issues, feel free to post a comment or contact us from our support page. Apologies for any inconvenience caused, and as always thanks for your support!
This post was originally posted on March 15, 2010
Share this
Tagged , , , .
