Cornwallbanner
Topaz Labs is excited to announce our soon to be released product, Topaz Clarity, a plug-in that helps you create powerful and refined images by intelligently enhancing clarity and contrast with absolutely no artifacts or halos. Topaz Clarity will be available next week.
Target Specific Contrast Regions
Topaz Clarity allows you to create flawless contrast and clarity definition with minimal effort. With just a few clicks you can easily manipulate your image’s micro, midrange, and overall contrast, transforming a photo from ordinary to extraordinary!
This cutting-edge technology allows you to effectively enhance various tonal regions and then increase or decrease the contrast and clarity in that specific variation, all while maintaining a natural feeling and tonality within the image.
collagecar
Breakthrough Halo-Free Algorithm
The proprietary technology behind the software allows you to boost your contrast and clarity without emphasizing transitions between light and dark areas, eliminating the common problem of halos, noise, and artifacts.
claritybeforeafter1
Advanced Hue/Saturation/Luminance Technology
Using IntelliColor technology, you can easily enhance your image with the HSL filter, allowing for stronger, yet more natural Hue/Saturation/Luminance adjustments.
Clarity collage 2
Re-Imagined Masking Workflow
Based upon a Reveal and Hide Logic, the masking module, now attached to each adjustment tab, contains a comprehensive set of tools including an edge-aware brush, gradient mask, smart feather tool, color aware tool and more!
To see it in action, attend one of Nichole’s Topaz Clarity Sneak Peek Webinars below:
Fri, May 17, 2013
1-1:30PM CDT
Sign up
Fri, May 17, 2013
3-3:30PM CDT
Sign up
Mon, May 20, 2013
2-2:30PM CDT
Sign up
Time Converter
Hope to see you there!
Share this
Tagged .
