If you’re anything like myself, multiple failures to create a ‘clean’ mask from more advanced images were conducted in Topaz ReMask upon first use of the tool. However, with a little bit of practice along with helpful YouTube tutorials, I became more confident with the program.
Here is a useful method I would like to share with you for objects that are a similar color to the background, in this case product photography. The technique behind it is the editing that takes place after the mask is computed.
Screen Shot 2013-10-24 at 3.55.40 PM
I first did a quick outline of the image in ReMask, not worrying too much about the blue outline’s preciseness, although it helps to keep the blue line as thin as possible.
1The computed mask was not perfect. This is where post-compute touch-ups come in hand.
3Here are some tips for making the most precise mask after it is computed:
1. After computing the mask, change the view to the 4-way display. This option can be found in the top right corner directly adjacent to the Topaz Labs logo.
Before 42. Use the basic brush (in both green and red) to brush out areas of blue, minimizing the blue outline in the tri-map. Zoom in and out using your +,- keys and try to create the thinnest blue line between red and green for the most accurate results, alternating which view you use to brush out the blue line. It is also helpful to refer back to the ‘Keep’ view when brushing in with green and red to see exactly where the object meets the foreground.
After (thinnest blue line for best results):
After
Fourviewmode3. Once you have completed the touch up process you can also make additional adjustments under ‘Mask Adjustments’ and ‘Foreground Color’. For this image I increased the ‘Recovery’ slider and then conducted a ‘High Quality’ compute to help the edges become less transparent.
Here are a few definitions of what each does from the user guide:
Screen Shot 2013-10-24 at 4.08.27 PM4. Don’t forget to make sure the ‘High-Quality’ option is selected in your Menu -> Preferences for the best results (Note: you must be in ‘Keep’ view mode to access the high quality option).
Screen Shot 2013-10-24 at 4.08.19 PM4. Press OK to bring the image back into Photoshop (or whichever compatible host application you are using).
transparent background5. Create a new layer underneath the masked image and fill it with black.
Final Mask6. Use the eraser tool with a reduced flow (around 40%) to smooth over edges. You might also opt to burn or dodge the edges depending on the background used to help the image blend in.
Screen Shot 2013-10-25 at 9.12.33 AMFinal extraction:
Screen Shot 2013-10-24 at 4.23.49 PMHopefully this offers you some ideas on how the ReMask program can be used. See our tutorials page as well as YouTube channel for more demonstrations with Topaz ReMask.
Share this
Tagged .
