A Topaz Product Update for Adjust and Simplify is Here! Topaz Adjust is perfect for brilliant contrast, detail, and color adjustments while Topaz Simplify creates paintings, sketches, watercolors, cartoons, and more! See what’s new in these easy to use programs, update your software with easy one-click links, and download a free 30 day trial if you do not already have the programs!
Adjust and Simplify Update
Check Out What’s New:
Adjust and Simplify have some new features you’re sure to love! We’ve updated some tech specs and upgraded the program to better fit your post-processing needs.
1. High DPI Display Support for Windows.
High DPI monitors now display Adjust and Simplify properly. The application GUI has been updated to display correctly.
2. Preserve Image Metadata.
The update to Adjust and Simplify now preserves all image metadata.
3. Separation of User Data and Program Files.
Computer user accounts now store saved effects separately for each computer user. User created presets are now saved in user specific data locations, in their own separate folder.
4. Import Your Effects Easily.
Adjust and Simplify automatically imports all of your saved effects from previous software versions!
5. New Effects.
Adjust 5.2.0 comes with 18 new effects. New notable effects can be found in the Stylized Collection, the Vibrant Collection, and the Toned Section.
Simplify 4.2.0 has 12 new presets in the Detail Removal and Enhancement, Line and Ink, Painting, and Sketch Collections.
Free Update for Adjust Owners:
With Topaz Adjust you can give your images the soul and character you envisioned in the field! Unlike our eyes, a camera lens can’t compensate for all the tonal values we see right in front of us. If you shoot something bright, you’ll lose all the details in the shadows. If you shoot something dark, the highlights will be blown out. You can try to correct contrast, details, and vibrancy yourself, but it’s difficult to make images pop like you want.
Adjust Update
Adjust Upgrade for Mac
Adjust Upgrade for Windows
Want to see more examples of Adjust? Visit our Adjust Gallery!
Free Update for Simplify Owners:
Topaz Simplify gives you a set of tools to create art that only you can make. Build a wide assortment of effects such as watercolors, oil paintings, cartoons, charcoal drawings, sketches, and more. Make your art uniquely personal instead of using cookie-cutter filters. Achieve better results faster with specialized digital art technology.
Simplify Update
Simplify Upgrade for Mac
Simplify Upgrade for Windows
Want to see more examples of Simplify? Visit our Simplify Gallery!
Try For Free!
Don’t have Adjust or Simplify and want to give them a try? Download a free 30 day trial today and see what they can do for you!
Share this
Share on Facebook0Tweet about this on TwitterShare on Google+0Pin on Pinterest10Share on LinkedIn0Share on Reddit0Share on Tumblr0Email this to someonePrint this page
Tagged , , , .
